1964 dodge polara dash housing
s5757s
1:27 PM
Battle Ground, WA 98604
Just had the metal housing powder coated and was wondering if there was any un seen areas where i need to get to bare metal for grounding purposes ?
Thanks
You might use some star type lock washers under the fasteners. They will bite in when tightened. Areas that can't be seen, you might sand off the pc. Old cars have enough ground issues so get ahead of them while its easy.
Grounding is the most important electrical connection. It causes massive problem, even today. Make sure they are good grounds, and it never hurts to add a wire from a component directly to the body, or even better, the frame.
