1965 & 1966 repair panel interchangeability ?????????????????
Redsat
12:53 PM
Australia
I have a 65 satellite as you guys know you can't get repair panels for 65 but 66 you can . Are the firewalls ,frame rails ,windscreen valance panels inner and outer interchangeable with a bit of modification??? What other panels can you swap between them with a bit of modification. I know I`m not the only one to have this problem.
Redsat
Australia
To my knowledge, they're COMPLETELY different--no interchangeability. However, all 64 and 65 Dodge and Plymouth B-body panels WILL interchange--good luck!
I believe that 66-70 B-body panels like the firewall, cowl, front inner fender wells, are interchangeable! Frame rails should also work.
The cars changed to a new body style for '66. You need to be looking at 1964-5 cars only. Nothing from 1966 and up body will ever fit a 65 with any amount of modifications.
Agree- 63-65 share a lot, 66-70 is totally different.
