1965 satellite power window regulator
mopar505
5:33 AM
pa
is it the same as a hand crank? got a power unit that the reguator gear keeps striping hence windw no roll up or down. motor runs strong.gears looked worn and no longer intermesh. whats the fix?
The hand crank is different. What part are you looking for? is it a hard top or convert?
I might have extra parts.
its a hard top.i guess i need the whole assembly less the motor and glass. been 20 years since ive had it apart.
I have pieces and parts of the power window stuff, most i have taken apart. i used the mounting bracket but i have the rest of them. mine were for a convertible and i know the rear regulators are different. if you can take yours apart, I might have the pieces that can make them work again. you may have to do some welding or grinding to replace the part you need.
ill take it apart and send ya some pics of what is needed. thanks
