superbee_68
I am troubleshooting wiring gremlins on my 1967 Belvedere restoration. I purchased a nearly perfect original dash harness. The headlight, engine, tail lamp, reverse light, and neutral safety harnesses are new. After installing all the wiring, some strange things are happening. One thing I noticed right off the bat is the plug for the hazard switch has all four pins next to each other in a 2x2 pattern. The hazard switch has four pins but one is not in line with the others and is not plugged into the connector on the harness. My original harness had this same plug. Do I have the wrong hazard switch, wrong connector, or is something else going on? Any help is much appreciated.
Symptoms include:
1. with headlights off, when you press the brake pedal, the parking lamps on the dash and brake lights light up
2. headlights on, brake lights stay on constant
3. hazard lights do not flash
4. turns signals work on dash indicator
Neutral safety switch is also not working. Changed from 3 pin to single pin switch on big block 727. Is there more to it than just changing the switch?
Blower motor is not coming on? This one should be easy to fix just have not tried yet.
Symptoms include:
