FOR SALE 1967 Belvedere I 440 4 speed
sawdust
11:52 PM
SE PA
Feedback: +1 / =0 / -0
For sale is my very nice and clean 67 Belvedere 2 door post. Everything new, rotisserie restored body. Nice street cruiser and strip capable car. Fresh PPG base/clear. PM if serious and want more information.
$27,500.
Description of build:
Engine build:
1974 440 block ( 1974-1979 RB blocks utilize larger thrust surface #3 main bearing for improved crankshaft thrust area). Block align honed, square decked and bored/honed with plates. All machine work done by Doug Myers Machine in Schwenksville, PA.
Probe forged race pistons 10.8:1 calculated compression, Molnar H-beam rods, Total seal rings, Clevite 77 bearings, forged 3.75 Mopar stroke crank, std mains, rods. Rod clearances .0025”, main clearances .0026” measuered with mics not plastigauge.
Melling HV63 oil pump. Ported Edelbrock RPM aluminum heads, professionally done for guide clearance and correct springs for cam. Crane adjustable rocker arms. Comp Cams XTQ 294 solid cam. Crane chrome moly 3/8 mechanical pushrods.
Intake is an Edelbrock RMP Edelbrock 750 cfm AFB carburetor with electric choke. Mopar performance mechanical tach drive electronic distributor. MSD 6AL ignition and coil installed on interior firewall away from engine compartment heat.
Less than 50 miles after break in.
Transmission, clutch, rear:
23 spline transmission, new bearings, shafts, etc.
New hurst 4 speed super competition plus shifter. Stock Iron 11 inch Bell-housing. New Hays SFI steel flywheel, Borg&Beck 10.5 clutch. 8 ¾ rear with high strength axles, green axle bearings, mopar clutch posi, 4.30 gears. New 10 inch rear drums and brakes. New Caltracs, mono-leafs, adjustable rear shocks.
Exhaust:
Ceramic coated headers by Doug, 2” primary, 3 1/2” collectors. Pypes 3” X pipe , Hooker Aero chamber mufflers, TTI 3” tailpipes.
Nice car! If I give you 15k will you sell it? lol just kidding! :lol:
However I'm interested in the paint code if it is possible? I've planned to paint in white my 69 bird. and yours pops out just nice!
