1968 Dodge Charger body
Pauli072
12:15 AM
Sydney
Question to ask guys.
Do you think I could build a complete 68 Dodge Charger from scratch using AMD panels with some kind of a jig. Chargers becoming way too expensive nowadays so I was thinking of buying a rusted out charger and buy it strictly for the numbers only that way I can get one cheap ?
You’ll have to remove the word
CHEAP…… from your vocabulary first …
Why don’t you just repanel a Crown Vic
Like the General Lee Jumpers do ?!?!?!
IMO if you can find a solid 2 or 4 door cornet that would be the way to go. Would get you a good base to start with. Roof structure on the 4 door would be different for sure but not sure how different the 2 door roof structure is. Good luck.
The charger sail panel/c panel is longer then any b body. I guess if AMD has the inner metal that could work. I would rather save and wait to find one. They are out there.
Keep looking, they’re out there. :thumbsup:
If you think from scratch is going to be less expensive you had better guess again.
US Car Tool had a complete Charger body built with AMD parts on display at Carlisle this past July. It is a joint venture between US Car Tool and AMD. The price for the complete assembled second generation Charger was $34,995.
Built totally from scratch without a donor part - it will need an entirely new VIN and registration process......like a new build.
Start with a donor and do the replacements will be easier.
It is the same deal as the Camaro and Mustang bodies available aftermarket where a donor tag is used.
You can’t build one without a donor car. There’s a few pieces they don’t make. I know because I went through this 2 years ago
Spend some free time reading through this. Don has incredible determination and skill, especially considering what many would consider an uphill battle with the body he started with.
Apparently AMD is making all the pieces necessary to build the whole car now. They had a complete AMD Charger on display at Carlisle.
The roof is 3” higher on the 4 door. I used to think the windshield interchanged with the 2 door. It’s taller as is the vent wing.
Just asking If a donor car is used or build from scratch. Isn't that a rebody car? That's a whole new issue? I think there are a few states in the US where that is legal for cars 1983? and older. I was told that there is really no Federal law against that as the
Fererallies passes that down to each State.
