SOLD 1968 MOTOR, TRANS AND REAREND
MrFuryMan
9:19 PM
Canfield, Ohio
Feedback: 1 / 0 / 0
Selling a complete 1968 motor, transmission and rear end from Barracuda. It’s all original 318 motor with a two barrel, 904 transmission, and a 7 1/4 rear end. Odometer shows 65,000 miles on it. And I purchased it from the original owner. Believe to be the original miles. Motor runs fine and there were lots of records of maintenance. Most recently, the carburetor, the water pump, and the starter were replaced. I am selling this complete with exhaust manifolds, air cleaner, driveshaft, leaf springs, power, steering pump, alternator, and radiator, etc. The picture you see was taking on April 2. This car was driven from Michigan to Ohio and was roughly a 6 Hour drive and it ran great. It’s obvious that gaskets have been replaced and doesn’t seem to leak any oil. There is evidence it did leak oil in the past though. And normally I would just put this in the corner of the garage and keep it in case I ever needed it again, but, I really don’t have the space right now and I don’t want to see the engine go to waste. I’m asking $750 or make offer. Located in Youngstown, Ohio. PM for more info
