1968 Plymouth GTX
Rod bearings came. Got four pistons installed so far.
Making progress. Heads and intake manifold are ordered and on their way. Also ordered a Carter M3672 fuel pump. The old pump was broken in half.
Heads and rocker shafts installed.
Test fitting the manifold. Ran out of the Turquoise paint so will need to wait a bit before proceeding.
Valve covers are just sitting in place. I have had these in storage for over a decade. Thought now might be a good time to put them to use.
Heads painted, fan and pulley installed. Still waiting for new parts to arrive.
Also, it turns out my Holley 850 is so old that Holley doesn't even list parts for it on their website. I emailed them and they said I had to call and speak to an order specialist. LOL
Ended up reusing the alternator brackets as the one I ordered from 440 Source didn't fit.
Alternator is installed but I don't have a belt so it's sitting in place.
Order a new power steering pump, not realizing that It didn't come with a cap.
Did the engine have two fan belts installed? Right now it appears everything is aligning with the rear groove in the crankshaft drive pulley.
Which brings me to another question. I found that I have two extra drive pulleys. One is like what I have on my engine measuring somewhere around 7 3/8" with same size grooves.
The other is about 6 5/8" and the inside groove appears smaller.
The bolt pattern and center hole are the same.
Any insight into which one goes with what engine would be helpful.
I just installed the new power steering pump and pulley but it doesn't line up with the front groove on the drive pulley. Its centered on the front lip of the drive pulley rather than the groove.
Is there a way to adjust it? I tried loosening the bracket bolts but it didn't change much.
Amazing how many modifications and problems you find in the wiring on these old cars.
Here they put a jumper cable to bypass the ballast resistor. There was a similar one behind the dash that eliminated the panel light switch.
Removing the harnesses from the firewall connector. The top one is for the wiper motor:
Next is the voltage regulator, washer pump, horn side harness. Note the fusible link:
A couple of splices and dead ends in this harness:
The final connector is for the headlight harness. Notice the yellow lead running to the relay. It is attached to the plug by one single strand of wire:
The connectors for the dimmer switch, console, dome light, trunk and tail lights is behind the driver side kick panel.
Of course all of these are wrapped with tape and labeled upon removal. You end up with a box full of wiring harnesses.
When I did my GTX I went ahead and ordered all new wiring, simply bc the internal wire just became so brittle
I was surprised to find that the cylinder heads that came on my 440 were not 906s but actually 908s. I have never heard of 908 cylinder heads before.
Thought I would put them up for sale but have no idea what they are worth? Can't find much information on line, other than they had larger valves and came on the smaller V8s.
I haven't been working much on my car lately. Just came back from my second motorcycle ride in northern California.
Did install insulation on the roof and began installing the headliner. Can't say that I have been having any fun with this project. Broke a bow clip and had to order more, then I broke two of the inner windshield molding clips and couldn't find anyone that had them in stock.
I ended up using a nylon nut insert and #8 metal screw with a flat washer on it for the two corner clips.
At this point I only have the front edge of headliner in place. Hopefully the edges and rear window areas will be easier.
Using a heat gun to warm the material when installing but I have a lot of wrinkles to deal with.
This car was completely disassembled when I bought it. I did get some pictures from the previous owner of it assembled so I am hoping maybe someone on here is familiar with this ignition set up.
I have all the parts in a box but not sure if it's worth the effort to reinstall it?
Here's a picture of the distributor and connector:
That’s an electronic ignition distributor.
The red radiator is a nice touch.
Looking at my 727 transmission, I found the numbers indicate that it was for a 383 motor.
I was planning on giving it a good look over to see if it needs to be rebuilt (guessing yes) but don't want to waste my time if this transmission will not support my 500+ HP 440.
Tried searching for information and there is a ton of it, some saying it will be fine for a street car, others saying it will need a shift kit, etc. I don't plan on racing this car but still want it built for performance.
Suggestions needed on how to evaluate what I have now. Also, if there are any good videos on rebuilding available? Then I will be better able to make a plan.
Happy Thanksgiving!
Here's the number: J2801543 4038179
It also has this on the side:
Whoever had the car before changed the engine and transmission. The engine is 1970.
Anybody rebuild their own transmission?
Also, looking at headers, the Headman Headers I purchased for my signature car have gone up $500 in price to over $800 a pair now!!! They have the uncoated ones for about half that price.
What are y'all using and what diameter pipes. I was thinking 3" diameter with Hush Thrush Turbo mufflers.
