markbob
Hey all....
have a 4 wheel power drum brake system....
I have all new stainless brake lines and wheel cylinders....
the proportioning valve and master cylinder are original to the car when I purchased it...
I hooked everything up, and bled the front brakes....then I moved to the rear....everything was fine until the rear of the master cylinder began leaking and fluid ran down between the master cylinder and brake booster....
I purchased a new master cylinder, and installed it....
today I filled it up and began to bleed the brakes....I bled the front and it appeared to go fine....
I tried to do the rear brakes and there is no fluid coming out of either side....
I disconnected the ss line from the rear flexible line.....no fluid in there either(other than a few drops).
I moved to the proportioning valve, and loosened the line that goes into the top of it from the master cylinder....a hiss and some fluid....
I tried the front brake line ports....got fluid to come out....
I tried the rear brake line ports, and nothing....not a drop
any ideas? I am thinking it's either a bad master cylinder, or there is a blockage in the forward line that sends fluid to the rear brakes....
Help...please!
Mark
Help...please!
Mark
