1969 Dodge Coronet R/T
OhioMopar
5:45 AM
Mt. Gilead, Ohio
Feedback: +0 / =0 / -0
Original '69 Coronet R/T. Was an auto on the floor, air, bulge hood, bucket seat, console car with standard dash. Now Ramcharger hood 4 speed, buckets, rally dash. No fender tag or build sheet. CLEAN OHIO TITLE. VIN matches core support and trunk rail. '69 HP 440, 18 spline Hemi 4 speed, 3.54 Dana. Lakewood, Centerforce, Hayes, Mopar Performance, Hurst, Centerline, Holley, all new suspension and brakes, restored cluster. Right Stuff lines, tti headers and exhaust, new tank, lines, electric and mechanical pump. Runs, needs finished
$15,000 obo. Would be more than willing to trade. No /6 cars. Darts, Dusters, Demons, Satellite, ect.
I am located in central Ohio.
Bump
Here is a list of the stuff I have put into it. New outer bearings, studs, shoes and harware, turned drums on the Dana.
New u-joints in the drive shaft. New gas tank, sending until, sock, pad, lock ring, ground strap, retaining straps, The Right Stuff stainless 3/8 lines and return line. Holley black pump. Jegs relay kit. Carter street/strip mechanical pump. Rebuilt Holley 850 dp. Mopar M1 single plane intake. Mopar .509 purple shaft. Shumacher Poly-Loc motor mounts. Moroso 8quart pan with pickup. Melling high volume oil pump. Aluminum radiator. Udated dash harness. Centerforce Dual Friction clutch, Hayes Flywheel. Centerforce t.o. bearing. Lakewood Bellhousing. New Rigth Stuff brake lines. Rebuilt power booster and new master cylinder. New dash harness. Rebuild cluster. SMS rebuilt door and hood hinges. New repop hood scoops and bezels.
Much, much more.
$13,500 or trade up down or across. I have $3,500 I can throw your way for the right car.
The pics look bad but this car is SUPER solid. Western body. Clear and clean Ohio title.
Just running out of steam and $$. Went through a divorce and a move last year and don't have much room in my small apartment garage to work on it.
i have a 1971 Scamp, it has a 340, with a auto trans. 8 3/4 rear. pretty quick car. it's from VA.
i also have a 1984 1/2 Mustang Gt, it's a 20 th anniversary car (GT-350) model, this car is very rare and all original with only 19700 miles on it. it powered by a 302 with a 5 speed manual trans. it's in excellent condition, always garaged, never seen snow.it has power windows and locks. pics do not do this car justice.
here are some pics of the mustang
the stuff on the inner fenders and firewall in the engine compartment is the factory rust proofing, just to let you know
They look like some pretty sweet rides, but I am looking for a street car. Don't do Fords. Thanks
