EWJ
1969 Plymouth Satellite Convertible Project- 383hp (H Code), four speed, tachometer (N85) car: basically, a Road Runner convertible in Satellite trim. Fender tag, no build sheet. Not original motor or transmission. One of 14 built according to GG. Y2 yellow with black top and interior. Solid quarters (need lower patches- not replacement). Clean cowl, dutchman panel, inner fender wells/engine area, and convertible top well area. Needs interior floor replacement, trunk floor replacement, rear frame rails and shackle mount replacement. Front driver's side frame rail needs patching or replacement. Comes with a ton of parts, and everything for the car is neatly, carefully packaged and labeled. Overview of parts is as follows:
Car is in storage. Pictures listed show how the car was when acquired and now how it is. I can get some additional pictures- but I prefer it to be viewed in person. Car is located in Northern NJ. Can show it most anytime. Cool unique car for someone who has the talent to do the bodywork. Asking $11,900.
- 1970 383 with 440 Source aluminum heads- complete from air cleaner to oil pan: heads disassembled, inspected and upgraded with 10-degree retainers. Lunatti cam and springs. Motor fully assembled and detailed from air cleaner to oil pan including exhaust manifolds and ignition system. Rebuilt 23 spline 4 speed.
- Original dash fully restored including gauges.
- New top
- NOS grille
- New master cylinder and power brake booster
- Original side glass and related mechanisms are fully cleaned, carefully packaged and ready to install
- AMD Front Fenders, P/Ns 200-1469-R and 200-1469-L
- AMD Doors, P/Ns 500-1469-R and 500-1469L
- AMD Rear Frame Rails, P/Ns 895-2468-R and 895-2468-L
- AMD Front and Rear Bumpers, P/Ns 100-1468 and 990-1469
- AMD One Piece Trunk Pan, P/N 800-1468
- AMD Driver's Quarter Panel (badly damaged- good for lower patches only)
- AMD One Piece Interior Floor Pan, P/N 400-1466
- AMD Rear Footwell Area Floor Pans, P/N 410-1466-P
- AMD Quarter/Trunk Extensions, P/Ns 840-1468-R and 840-1468-L
- AMD Four Speed Hump, P/N 415-1466
- AMD Rear Crossmember, P/N 870-1468
- AMD Rear Leaf Spring Mounts P/Ns 865-1466-2R and 865-1466-2L
