dedline
Hello everyone. I’ve got a 1969 Plymouth Roadrunner with an upgraded 440. My son does the electrical for me and is the one writing up this post.
I have a problem with the fusible link getting too hot, so hot you can’t even touch it. It only gets hot when the engine is running. I can turn the key to the on position with the engine off and everything is fine. The fusible link appears fine and doesn’t look like it’s being damaged.
The car has this problem about 90% of the time. The other 10%, the fusible link stays reasonably cool. I ran it the other day for a short time and the fusible link stayed comfortable to hold. So, the problem appears slightly intermittent.
Recently, I’ve added two electric fans and a vacuum booster for the brakes. The fans run off of relays that get their positive directly from the battery and the booster is wired into the fuse box so it gets power when the key is on.
The car is running an upgraded alternator, a Powermaster 100 amp unit. The bulkhead connector is clean and properly snapped into place.
Any ideas where to start troubleshooting? Thanks
