I did not try a Borgeson. I used an off the shelf, aftermarket box, that you can get from the supply houses. Those boxes have a different designed case that does not use the external balance pressure valve. Therefore the case hits the headers AND, I've now discovered, I can not get the column coupler to engage the input shaft on the new gearbox. Third problem is the box doesn't come with the HP fitting on top. The original off the OEM box does thread into the new box BUT not deep enough to seal, even with a new crush washer. I ground the bottom of the fitting a little and still can't get it to seal. Start it up and pressurize the PS system and fluid sprays all over the frame and floor! I've come to the conclusion that I'm gonna send my OEM box to Steer N Gear or FirmFeel for rebuild.
