1970 Rally Dash wiring questions
Dutchrebuild
2:29 AM
Have a new M&H under dash harness I'm installing before dash goes in my 70 Super Bee.
Question 1...the m&h harness has a lot of extra wiring that is specifically for a Chargers hideaway headlights....what are you guys doing with all the extra ends? Seems some would be live. Don't want a short out....
Question 2... My car has the reverse light on dash for 4-speed....single black wire coming out of the light...where does that wire go? Been staring at the FSM for hours and struggling to figure it out.
1- Charger harness is different than other b-bodies with the rally dash I think.
2-Reverse light is fed off the bulkhead. I believe its terminal Z.
Place some heat shrink tubing over the exposed ring terminals and tuck away, they are energized under some conditions. Reverse indicator lead needs to go to cavity Z in the bulkhead connector assuming you have the correct 4-speed reverse switch harness.
I put the same M&H harness in my Bee just taped of the extra wires. Pnora is correct
