1970 roadrunner dome light
eddie w
New Member
3:23 AM
new york
I installed new door switches and I still get constant power to my dome light any help greatly appreciated
Passenger map light works correctly
Thanks for any input
ed
Is your headlight switched turned up for the dash lights?
You should have constant power at the dome light housing, the dome lamp is switched on the ground side (yellow wire). Are you saying the light stays on, not going out with the doors closed? Be sure you are running the correct bulb, #1004.
