manes
Zip code 34953
1971-74 original dash wiring harness.
Was removed from an; 1974 charger se Brougham. There are a few cut wires but no major ones:1 cut I believe is the door buzzer and the other is cut on the other end of the connector so I believe that one is not on the harness, Note the one of the connectors’ plastic casing has dry rotted a bit. With the pictures you should be able to trace anything in question or if you need further answers please ask. $275.0
Thanks.
Thanks.
