Davison
A few years ago I installed a Delphi fuel pump for my 440-4bbl. It runs fine. No issues on how I drive it-mostly for causal drives or to car shows a few times a month. 60 mph tops. I brought the car in for it's annual checkup and the mechanic said he thought the pump pressure at 4.4 psi was too low. The 440-4 should have more like 5-7 psi. the car runs fine as it is. What's the group's opinion? Will I gain anything if I go to a higher rated fuel pump? If more is better, then how much is too much? How much will overpower the carb and flood it? Thanks.
