1973 rr clone
Chris1973Rr
5:42 AM
New jersey
Looking to put a 68 383 in my 73 satellite looking for advice on how to do it
youll need BB motor mount brackets for a b body and a new driveshaft and of course a BB radiator.( with a shroud! )
if nothing stock is laying around,Schumachers will be your go to there.
im not sure on the k frame when they went to the isolated rubbers.
deffo should check into that,and if possible,eliminate those rubbers and use solids.
also,you should try to hook up with Bruzilla on here.
hes loaded with info.
My advice for anyone wanting to do this swap is shop around for a rough donor car, usually an old C body, and buy it. That'll give you most all the parts you need to the swap. About all you'll need is a set of Schumacher mounts.
Then, when the project is done, part out the doner car and make back your money. :)
'73 and up are spool mounts, better to get the mounts at Schumacher, k-frame is different between small and big block. That's assuming of course that the car was an original small block.
