Brandy
Jack Stand Racer #6..and proud of it!
- 8:47 AM
- Oct 16, 2014
- Salisbury, Vermont
Selling a 440 out of a motor home. It ran well before it was pulled. The engine is missing valve covers, valley pan, dizzy, oil pan. Can include a set of factory exhaust manifolds. It comes with a stock 440 intake and water pump and a 600CFM Holley.. this engine is an "RB" block, cast crank, "902" heads,8.9:1 compression,4.32 bore/ 3.75 stroke, built in Trenton 6/4/1974. From what I have gathered so far, the open chambered "902" heads flow as good or better than the "906" heads. This motor has the raised rib along the sides of the block just above the freeze plugs, thicker ears, 10% more cast iron in the block. It has been kept in the garage and covered and coated with oil to defeat rusting and turns freely.
$ 400.00 firm.
$ 400.00 firm.
