69superbee383
In the process of swapping 3.55s to 3.90s in my 8 3/4 489 case. Wanted to see if anyone wanted to lend there opinion on my gear pattern. I attached a picture of first mock-up with the .032 shim I took off 3.55s you can see it is very close to face of tooth. The other picture with the more centred pattern is best I have gotten this far that is after adding .014 of shim on top of the .032 I started with. I feel I’m pretty close do I call it quits here or keep playing with it? Also a little thrown off I would have expected to run a smaller shim switching to 3.90s not add.
