I have a 1969 coronet with a 3 speed wiper motor. The motor gets hot to the touch when it has power to it. The grounding strap is grounded. It doesn't work obviously. I've changed the ballast resistor. Any ideas?
I got the motor off finally, that was unpleasant. The first linkage is loose and the wipers are ceased. You guys are sharp! Any tips on freeing them? I gave them a little tug and no movement.
Ok thanks! I have a bigger problem now though, I broke the right hand side wiper pivot base. The left is free. Wouldn't happen to know of a place to fine one?
