...and that's not all.....You will need the steel engine brackets from the 440 and the rubber insulators from the 318 engine mounts. Bolt the rubber insulators to the 440 brackets and the engine will drop in place on the K frame. You will also need a big block transmission. The 318 transmission has a different bolt pattern. You will also need a radiator meant for a big block or have a rad shop move the lower inlet from the passenger side to the driver side. Alternately, you can use a late model 440 water pump housing that has inlet on passenger side.
its a 1975 440 out of a titon motor home complete with wires-rad- trans-p/s pump ...That poly is over 600 pounds, and is easily documented. even 70 lbs difference can be compensated greatly by getting an aluminum manifold for that 440.
a 383 with factory A/C weighs the exact same as a 440 non a/c..
also, the bracketry on that old poly weighs more than the same parts on that 440.
my car drove exactly the same after I converted from the poly to the 440.
However, I did have a 70 roadrunner K member, so I went one step further and Installed it along with the factory sway bar. The car is now really tight.
all polys also came with the 727, so the cross member, transmission kickdown linkage, and and driveshaft will fit as well. if you go 440 the biggest decision is do you go pre 70, or 70 up? The 70 up has the bottom outlet on the passenger side.
this sounds minor, but that also means the timing mark is reversed to the other side. so you can't easily match a newer (70 up)water pump housing with an older harmonic balancer. the marks won't jive. Just buy a 22 in radiator that works with whatever year engine you choose to buy.
If you have P.S. now, you simply have to get a pump that works with the correct engine year brackets you aquire. That stuff is all obtainable, the main thing is that engine will bolt into that car. Your present radiator is of no value, as the bottom outlet is also too small of an outlet for the 440 housing.
as far as handling, that car rolled around corners with the Poly, and will also do so with any engine in it. A sway bar is necessary no matter if you did nothing at all.
I would not let any of this discourage you, it is a good idea to do it, and many guys here have plenty of parts to help you switch it over.
the good thing it is a 66 model, so most everything is Interchangeable with 67-69 models.
and im old school i like rolling around corners and floating alongits a 1975 440 out of a titon motor home complete with wires-rad- trans-p/s pump ...
it sounds like you have everything, except a 22 inch radiator for a HP big block. I haven't seen a 66 sway bar, that is just something to deal with later. rolling around isn't so bad, what is the hurry anyway?its a 1975 440 out of a titon motor home complete with wires-rad- trans-p/s pump ...
we are saying pretty much the same thing, we all want to give the guy choices.Hughes Engines website lists the Poly at 600 lbs (estimate).
In my Brooklands Book for the Chrysler Small Block, one article on the 273 when it was first released says a 40 lbs saving on the block and 12 lbs on the heads. Another article says 55 lbs saving overall.
Take the higher weight of 55 lbs plus the 525 lbs listing for the 273-340 = 580 lbs.
An aluminum manifold can also be used on the poly (e.g. Weiand 7503, Chrysler Windtunnel etc) although I accept there aren't as many choices.
You're in the 440 camp which is fine - I was just giving the OP a choice, as a poly stroker can give him plenty of power and torque. It all depends on his intentions for the car. If he wants 500+ hp then go 440. If he's looking for 400 hp, 400 lbs/ft then a stroker may be a cheaper/easier way to go.
