1966 poly 318 oil capacity
TonyB
4:54 PM
Minnesota
Confused on poly 318 oil capacity, internet says 6 quarts with filter, downloaded original manual says 5 with filter. i am at 5 and it already seems to show a little over full on dipstick, stock oil pan and wix 51515 filter. Any info will help. Thanks
I would run it with the 5 for a short time and check again. Go from there. It will let you know how much oil it will be happy with. Just don't over fill.
5 with filter is full. Record where that 5 qts shows on the stick you have so you know.
Let the dipstick be your guide.
I had that engine back in the 70s and 80s in my previous 66 Coronet. It was 5 quarts with a filter.
5 quarts with filter as per the Factory service manual.
...but the Internet said 6. :poke:
I put 5 in my '66 Poly.:)
AI doesn't own a Poly. The truck/ motor homes may take 6. I don't have a manual for those.
