318 poly water pump pulley question
My 318 poly 65 D100 came with a double groove alternator so it has a 2 groove water pump pulley.
Keep in mind your bottom pulley will also need to be those same two grooves with the same diameter...
You will need a 3 pulley bottom if power steering is used...
