how hard is it to replace the rear main on a 74 318? my spare motor leaks a bit and might as well change it before she goes into my next project, Thanks.
IF the original is a rope type seal they can be a bugger to remove from the block without crank removal. 69Bee got ya started.Sounds like it's out of the car and on a stand.You may have to remove all the main caps and lift the crank some to remove the old seal from the block.
The motors out of the car? That's a walk in the park. pull the pan, pull the last main cap, change the seal, reassemble in reverse order. Don't forget to tighten the main cap properly. use a new pan gasket if needed. Crack a cold beverage. Done
