74Runneer
Im in the middle of a semi engine rebuild. Im putting new heads and intake on my 74 318. The heads are #302 casting swirl port heads. I'm putting an edelbrock performer intake instead of my edelbrock street master intake. I pulled heads, intake , and accessories are off today. I cleaned the block a little bit and sprayed mopar blue engine paint where the eye can see and ill pick it up tomorrow.
My question is: On my old intake there was this oddly shaped half inch thick plate that was on the drivers side right under where the linkage would be. My new intake doesnt have the screw holes tapped yet but it does have the spot where it should go. Is this something for the choke? Do i need this anymore? There are no wires or anything going to it.
My Second question: There is this fitting that was attatched to the new performer intake. There wasnt anything like it on my old intake so i am confused?? Its on the drivers side towards the back of the intake. Hmmm?
Final question: Can i get rid of the the header studs that are in the heads? They are off of an 86 dodge 318. They have studs on the first and the last header bolt holes. Due to clearance issues id like to get rid of the studs and get some normal header bolts. Are these studs jutting into the some passage where i need to keep them? Thanks!
