318 to 440 CONVERSION
lordofrc
7:47 AM
Long Beach
I have a 67 charger with a 318. I am building the 440 and getting ready to put it in the car. I purchased the 727 torqflight. What modifications are needed to put the 440 in the car other then this. Driveshaft length? throttle linkage?
Ignition system wiring. The BB dizzy is in the front on a BB, and the rear of a SB. The harness needs to be extended. Make sure the water pump inlet matches the outlet of the radiator on the bottom. I'm sure others will chime in with their "gotchas".
Okay thank you everyone. I'm also making it a console shift car and I put all the mounts in and the is a bracket missing for the shifter shaft
Keep in mind that you need fuel lines with a bigger diameter, too.
