96Formula6sp
So a while ago we found a piece of what I am guessing is a section of the valve spring rotator. Here is a picture of what I am talking about.
We removed the ring and have since run the car. This was on the exhaust valve on cylinder #2 This car is going to a track day car so this needs to be fixed. I would rather not drop a valve. So a couple of questions. First off what is that piece. I am used to more modern cars with a shim on the bottom,spring, retainer on top. Second at this point we want to replace the the locks and retainers or whatever this piece is. If this means replacing the valve springs as well we will. Car is a stock cam 318 with stock heads.
So what is out there for a good quality set of valve springs. There are no plans to throw a camshaft at it.
