375 runs, aprox 900+ hp. What parts will it need? Lets see
Were those header gaskets impeding exhaust flow by that small edge enough to cause a disturbance in the runners?
Not by much. But my bet is they will seal better. We were joking today that better ring seal, clean valves with unobstructed flow, no vacuum leaks at the carb bases it'll probably run exactly the same. I may move the cam a bit. It's straight up now at 111 ICL. We are going to talk about it this week. It's 285/296, .826/.800 on 111 lca.
Doug
Doug
How have the springs read?
322 psi (+/- 3 psi) at the 1.950" installed height. The rest of the valvetrain. 1200 series prings, titainium retainers, machined locks are all Pac. Trend 7/16" x .165" tapered pushrods. T&D paired 1.7 rockers. Jessel belt drive. Ferrea 2.35"/1.81" 11/32" 6000 valves.
Doug
All pulled apart except the pistons off the rods. Everything is cleaned and washed. Not bad for starting Tuesday.
Doug
Doug
Just my 2 cents. I’d advance the cam. That’s the same cam I run and Tim.
We are both installed around 106 so 5 degrees up. I’d be willing to bet it’ll make more power with the cam advanced.
Waiting on getting the valve work touched up, pistons coated, 4 rocker shafts, and head gaskets. The it can go back together. Now I'm bored. Replaced the oil cooler (under the intake) on my Grand Cheerokee to repair an oil leak. What a gooey mess. So today might as well clean up the car for the reinstall. Waxed the engine compartment and front suspension. Ya, I know I'm nuts. Polished the grille, front bumper, and front wheels. Do the rears tomorrow. Going to pull the rear bumper off and have the chrome fixed. It' was redone when i did the car, but now its peeling. Must be all that bad weather it sees inside the trailer.
Doug
Doug
A diamond NEVER in the rough.
I'm curious about the piston coating? Who/which coatings, and top/skirts or both?
I have been collecting parts for two new stroker engines and thinking of having ceramic coating on the tops and the skirts with the low friction coating. Been looking at the Ceracoat V-136 or V-139 piston top coating and the Micro Slick for the skirts, but not sure which one? There is the C-110, P-109? Not sure on the uses of the DLF-200 Dry film lubricant?
I love how the Jbars were done in that.. it breaks my heart when i see guys remove the aprons :( Plus they add a ton of strength
Line to Line. They have all different coatings available.
Line2Line Coatings™
Doug
Got the mains measured up. Like last time they are a little tighter than I would like (.0025"). But I'm to cheap to buy a second set of mains to mix and match. The old mains except for dirt scratches would've been usable. So crank is is in. Rear main is in. Cam is in along with the timing cover and Jessel assy. Made a preliminary move on the cam sprocket to advance the cam from its 111 straight up to 108. When the pistons come back from coating cam timing will get double checked. Heads are back from valve work and a .002" skim cut. Valves are in the heads, new seals, and all the heights measured. All are 1.950" +/- .005". Just need to grab some more shims and install the springs. The #2 intake was a little wobbley when gound. Have a new one coming. The seats were all a touch low on the area near the exh valve. All the intakes were slightly out of round on the face. The exhaust valves and seats were all in better overall shape than the intakes? There has never been any piston to valve contact. Spring pressures checked above the published spec. Replace te damaged rocker shafts and assembed all the rockers. Repaired the fan wiring where the disconnect melted. Added a seperate ground for each fan this time. Epoxied the water pump passages in the motor plate to correct some pitting. Just waiting on the 1 valve, piston coating, and head gaskets. opened up the the ring gaps some (old rings AP stainless, Napier 2nds). The tops are now .024", 2nds are .034", and the upper oil scrapers are .036" This seems to be the new theroy. So I'll see.
Doug
Doug
Sounds good Doug. Thanks for the update. Can’t wait to see what it does with the cam advanced 3 degrees.
Heads are together. On my way to pick up the pistons. If I can get the Racepac bung welded into the pan it'll be ready to drop in this weekend.
Doug
Doug
Man Doug that is nice to have your machine work get done that quick. Right now that is our biggest holdup at the Bowman shop. Machine work. Have 4 engines waiting on machine work currently. Happy to see you get it turned around quickly. Spring is approaching!
RJ
Have two friends that run machine shops. Normally I wait like everybody else. But if its my racecar stuff they do it as soon as I bring it. Really nice. I've had stuff repaired during the race season in a week.
Doug
It was all going good today, until it wasn't. Caught a 2nd compression ring in the ring sleeve. It's prety snug and the rings are only .0mm. It got out of th ering groove before it made it down out of the tapered portion of the sleeve. I'll cal Kevin at Total Seal Monday and get a replacement. Right now its a V 7.
Doug
