383 conversion
67dodgecharger
New Member
10:14 PM
Quebec
I got a 67 dodge charger with the original 318 and I want to put a 383 in it. I want to know what do I need to change except the transmission, headers and crossmember with engine mount. I don't want the front to get lower so do I need to change the suspension? Or any other things?
This has been covered quite a bit here but some of the highlights are engine wiring harness, motor mount brackets (K member is the same), check radiator hose fittings for proper location (BB lower is on left side), throttle cable bracket and kick down linkage parts. You can crank up the torsion bars to make the front end sit where you want or just install some big block bars.
