BBodyBarrett
I like the comp cams, they have some good choices. Thats probably what I will use. The machine shop is very good with Mopar engines, he is working up a cam / piston combination for the engine. I plan to use headers and a 3:91 gear. Thanks for the inputi'm familiar with the 284/484 and it has it's place, but I think it's still a step too far. the 284/484 (the one I measured was actually 286/486) is ground on 108CL and will have about 72 degrees of overlap at the seat. of course a lot of this depends on what you plan to do with the car, race it or street cruiser. I think you'd be much happier with something like a comp cams 280/480 ground on 110CL; about 60 degrees of overlap. cams with higher overlaps aren't real happy with cast iron exhaust manifolds. my car was a '68 road runner 4spd car I bought new in '68. I specifically remember that the more I cammed the worse it ran; on the street and track. the best dual purpose cam I ran was a crower 201hj; no longer available. my car wasn't sloppy tuned. the engine just didn't like big duration with high overlap. even with some of the smaller performance cams your tuning abilities might be challenged with a 383.
