miller
They used to have .001 , .002 undersize bearings, to get clearances where you want them.
Not available anymore?
nothings available that i know of. i'd need something like an .011" under which was never made. there are some .001" under race type bearings out there but nothing that would apply to a stock build. i'll have to get creative to whittle at this problem. i hope all the 383/400 people out there doing a build take note of this post. this is a real problem.They used to have .001 , .002 undersize bearings, to get clearances where you want them.
you are correct. clean-up everything, install new bearings, check with dial bore gauge and then give the crank grinder a number to hit.That's why you buy bearing before turning a crank. Get it turned to your clearances. Plan and simple
hard chroming used to be common back in the day. doesn't seem like anybody does it anymore. lunati did a bunch of crank hard chroming some years back but don't think they do it anymore. the journal sizes on the crank i have are good; if i had the correct bearings.Probably not an option you'd look at, lewtot, but something I had done on a 383 steel crank, probably 35-40 years ago. Almost doubt you could find a shop that does it, now.
That 383 crank was .006-.007 undersize. Just outside Dallas, was a well known crank grinding shop. At that time, many drivers were having their cranks re-done, something that shop did alot. Also had mine done the same way.
They would grind all journals to -.010 from standard. Then, using a flame metal spray, would build each journal oversize, with hard chrome. Once done, the journals were simply ground back to standard. Had been told alot of fuel car drivers would have that done, even to new cranks, since the journals would hold up much longer.
Worked great on mine, and was also able to close up end play.
thanks for looking!Nope, sorry Lewlot- all the ones I have are full grooves
