Neal Zimmerman
OK, back in December I started a dumb post called EX RACE CAR MOTOR< WILL IT BLOW ON THE STREET?, or some such dumbness. I finally dug it out today from under the work bench and I want to see what you guys think and test your Chevy/GM parts knowledge. More on that in a bit.
I Bought this motor in 2010 off Craigslist, from the son of the man that raced it. 350 bucks as I recall. Dad was gone and the son wanted to get rid of it. It was built for dads race car , a 67 Coronet, ( not a drag car, some kind of circular motion class). He raced it here in Oregon. This was built in the Late 70s or early 80s, before they had stroker kits for Mopar, so they welded up and then offset ground the rod journals on the crank, to stroke it by 1/4 inch, from .3.375 to 3.625. Main journals are normal 383 size of ( 2.625). This is where it gets weird. Chevy/GM guts! The rods are clearly stamped GM, but I cant figure out exactly what they are from. One buddy said they looked like Chevy straight six rods. They measure 6.75 inches in length and have a big end bore of 2 and 3/16. They obviously were polished and smoothed. The pistons are marked ROSS 425R, but I see no overbore marks on them.
Its kooky as it only measure out to 419 inches. Hardly seems worth the bother. Everything looks real good in it except that one piston, which the son did by trying to drive it on the streets for a week on pump gas, The compression was pretty high as it had seriously shaved closed chambered heads. I'm going to call Ross piston on Monday and see what they think and if they have an old piston laying around. The bore looks really good and zero lip on it so I think this motor was pretty fresh at one time. Pistons look good too except the one in question.
I took it to a guy here and he just wanted to start over with a stroker kit. I get it , he doesn't want to be liable, but that's absolutely what I don't want to do. I want to get this thing running in its old school glory and throw it in the pictured Coronet that's been languishing behind the garage for too long.
You guys have any idea on the rods and Pistons?
