4 speed trans with automatic radiator
moparjohnny
3:13 PM
ga
do i need to block off the two lower trans cooling lines ports or if they can be left untapped? thanks
You should not need to plug them if the oil cooling tubes inside the rad don't leak.
couple of threaded brass plugs ,won't cost much and its always better to be safe than sorry
Can't tell from your post I assume your running a separate cooler? Those lines supply lube to trans, you probably known that.
