- 8:58 AM
- Feb 29, 2020
- Heart of Dixie.....
Guys, got my used A833 installed and just began putting some miles on it. Ok, the problems, its quite noisy in 2nd and 3rd gear, and much quieter in 4th. I think that would be cured with new bearings. Ok, it will shift into 2nd, but pops out if not held in. I just swapped in a new Compation Plus shifter in this morning from Brewers and it made the shifting much crisper than an old Hurst original , very worn, shifter I was using. In planning for a rebuild, I know I need new bearing, but what is needed to cure the popping out of gear, a new slider, and/or a new second gear and/or possible shifter fork. Do these manuals have brass blocking rings as do Muncies? Some folks call these synchronizers , but I think the actual syncros, are cut into the gear itself? I know one cannot know for sure what may needed until its cracked open for a look, but I would like to get parts I know will be needed before I pull it apart.....thanks....
