400 B Engine, 512 stroker kit, 440 Source, Main Bearing #3 Mahle misalignment
Todd Millican
12:59 AM
Caldwell idaho
Freshly machined block, line honed. Installed ARP Main studs. On the #3 bearing journal, the alignment tab is off a bit, the engine side is almost as much off. The bearings are Mahle. Should I machine the tab, contact 440 source and see if they can exchange them? Has anyone ran into this before?
What is the set part number? What is the bearing shell part number? I also see a shadow of the oil hole in the bearing in the cap. Do both shells have oil holes, or do you have them installed wrong?
And there it is. I had the upper and lower bearings backwards. I'll admit I was stupid. Maybe someone will learn from my ignorance. Thanks all.
