400 ci satellite motor to Dakota 5spd?
Maxxx
8:37 AM
Waterloo, ON
Hello,
Wondering if anyone has been successful integrating a 5 spd manual trans out of a mid-90's Dodge Dakota with a 1972 big block 400 ci ? Wondering what is involved.
Thx in advance
Even if you went through everything necessary to adapt, can that transmission handle the 400's torque?
Mike
No idea. I guess it would be a grenade with its pin pulled? Or has anyone had success mating these two for a time?
I assume the most affordable option for big block Highway friendliness is a gear vendors overdrive? Presently my 72 Satellite has a 727 auto with a ~2.76 rear. I really don't want to modify the tunnel in any meaningful way if I can help it, though a custom console is coming since the car has already been converted from column to a crude floor shift at the moment. I plan on hitting a lot of bugs this summer, so I'd like to get the top end RPM way down.
You'd be surprised how well that 400 would run with a set of closed chamber heads (1.74" or larger exhaust valves), head shims, 750cfm carb, aluminum intake, and a beginner performance cam. Even with log manifolds it does well. Paired with 3.23 rear gears it cruises the hwy at a reasonable rpm.
By the time you bought everything including materials and labor for the fab work, you could probably buy a used GV unit.
I tracked them a few years ago and found the average price to be about 1.2-2K.
The hard part is finding one with a 727 housing extension.
GV rakes you over the cols to trade one in. IIRC they are about $800 bucks and they only give you $100-$200 credit.
Really a 2:76 rear and you want to bring the rpms down. Would be way more practical put a taller tire on it. 2500 rpm 2.76 gear 29" tire = 71 mph
Just about the right rpm range for best fuel economy.
Hello,
Thx in advance
If you're thinking of the Aisin AX15 transmission that was also used behind some Jeeps, they're popular with some s/b Chev and Ford swaps. I haven't seen adaptors for a big block Mopar though. Stock isn't good for more than 300 lb/ft torque but upgrades are available. If you're interested in the gear ratios, they are:
1st. . . . . . . . . . . . . . . . . . . . . 3.83:1
2nd . . . . . . . . . . . . . . . . . . . . 2.33:1
3rd . . . . . . . . . . . . . . . . . . . .. 1.44:1
4th . . . . . . . . . . . . . . . . . . .. . 1.00:1
5th . . . . . . . . . . . . . . . . . . . . . .79:1
Reverse . . . . . . . . . . . . . . . . . 5.04:1
I'm interested in replacing the 2.76 with something more aggressive while still maintaining Highway fuel economy
