Inspector71
- 10:01 AM
- May 1, 2012
- Lee's Summit Missouri
About 20 years ago I acquired an RB block. I was told it was a 413 Wedge. It has a turquoise four barrel intake that weighs a ton and seems flatter than the later 383 intakes. I've been told it's probably a late 60s or early 70s motor home block (I've got the heads, crank, pistons, etc. too). So I looked at the block number today. It reads 1852029. According to several books, this is a 62 Max Wedge block. Does this sound correct? I realize several forum members have advised against putting money into a 413 due to the limited selection in and cost of pistons but I've always liked the 413 and 426 Wedge blocks. If this is the real deal, I'd like to find the dual 4 barrel carb set up for which it was famous. Any info on this block number would be appreciated.
