BLK 68 R/T
- 10:13 AM
- Jan 10, 2016
- Taxington state
Didn’t realize it has had a different dist. In the past. I would agree with everyone else then on a timing issue.
I think some of the references are possibly the cam is over advanced.I guess I don’t understand how a timing chain impacts ignition timing if the engine’s ignition has been timed properly.
Maybe folks are inadvertently being unclear and are actually referring to the balancer mark being off.
Static.Sure. Still only blows 150 psi.
Your timing chain doesn't even need to be off a whole tooth. If it's a set with multiple keyways for camshaft degree-ing, it might be really advanced, or retarded, using the wrong keyway
Curious. Do you have a degreed balancer, or a timing tape on it? If not, I'd put a tape on it before I took anything apart.
For the avgas, I just drive on the airport grounds, put a credit card in the machine, enter my license number in place of the aircraft number, and self pump. (Into five gallon cans, NOT the truck!)I do it at my tiny az airport, but I think I could do it in a small airport in california...... but it wouldn't be cheaper than california pump 91
Fresno Chandler executive has a self serve 100LL , 24/7.Balancer only has paint marks. Adding tape on the reinstall would be simple enough.
Not sure I have any airports that small, around me. I'll check, just for the heck of it.
I use a steel can, so I ground the filler to that. Normally, a pilot would ground the plane. If you use a plastic can, you'll need to ground it to your car/truck. .
