bigrose426
New Member
world block,eagle rods,L19 bolts, eagle crank 4340 4.5, diamond pistons 10.2.1 4.500 bore,3/4 grooved bearings H/HNX rods,molly rings, milodon pan pickup 8 qt, hv oil pump, heads edelbrock casting , cnc porting flow 458, 2.25 intake/1.90 exhaust, stage 5 intake,2-750 edelbrock carbs, crane cam 565-580 roller, comp lifters roller, smith bro. push rods, bore and hone plates, square deck - crank rod pistons , balanced, mopar cast valve cover, pro billet timing set , fluid dampner, wide pad rockers used , ARP head studs $17,500.00
we have dyno sheets
673 hp at 5800
680 foot pound torque at 4000
we have dyno sheets
673 hp at 5800
