DoubleAwesome13
I want to put a '68 426 Hemi in my 74 Roadrunner. I know that the K frame will have to be swapped out but what else is needed? Do I need a K frame from 68 or will any year fit it? Any advice is appreciated.
I have found the engine and I am trying to see what I'm looking at for parts. It is a long term build and money isn't an issue. Its just a block and I plan on building it slowly. Just wondering what parts ill need aside from just an engine rebuild (K member, Transmission, Torsion Bars are what I know so far). As of right now its just a dream but im weighing my options between the 426 and a 440 stroked.Are you buying the engine or have you already got it? The reason I ask is a 68 hemi motor is going to be pretty expensive to buy if it's running and in good shape. If not, it's an expensive rebuild compared to the other more standard motors e.g 440, 383 etc. To then put it in a 74 Roadrunner, you'll never get your money back. I don't know your circumstances but the dollars are always worth considering.
My 68 Hemi is an replacement block. There is no numbers stamped on it. Casting date on the block is 11-9-68Please check the block to see if it has a partial vin stamp on it for all of us who are looking for there original engines. You mention it being a 68 and that could mean used in a 68 car if so that vin is stamped on the rear of the block flange that would mate up to the bell housing, close to the oil pressure switch location. If its a later block but still cast in 68 but used in later build car 69-up location is on passenger side oil pan rail. If you could check that would be awesome.
Matt
