440-6 Build: Opinion?
70runner
3:57 PM
Avocado country
70RR convertible: 68 440 block (.030 over) with repro 6pak carbs, 440source alum heads, stock iron intake and exhaust manifolds, stock rockers, SRP flat tops (approx 10:1), SCAT H beam rods, 727, 3.23 suregrip. Mostly street car with a little attitude.
Looking at following cam options: comp XE268 or XE274, Hughes whiplash (HMC3245BL-7), or Bullet Cams custom grind (.510/231, .540/238 with 108 lobe sep).
Converter: TCI 141200 (2.4K stall) or Hughes 24-25 (2.5K stall)
What think ye?
Buy one of Bob's cams. Best available for a six pack, and ditch the 3.23's
(btw....this was with a 4 speed, PolyGlas tires, NO traction, and 3960 pounds)
best of a 12.800@110.6
OK - who is Bob and where are his cams? What is an MR six pac cam?
my pal Bob. He's had his M code since NEW, and grew up next door to Hoover.
Kinda odd that the RT "drives around" the GTO and still has a lower MPH unless the GTO is doing it in the very last few feet and can't catch the RT....
I think it's kinda odd that the Goat's rated at 20 hp less yet pulls 2 mph higher through the traps.
Actually my best ET/MPH was 12.800@110.6, but that was in qualifying, not eliminations. Also, tire spin at the start tends to give you more mph in the traps
