440+6 Factory cam
clazar
11:19 AM
Pittsburgh
I'm going to do a rebuild on my 70 RR 440+6 this winter. One of the things i'm going to replace is the cam. I'm trying to find a factory 3 bolt cam & timing chain. Any suggestions where i can get one. I can find it for solid lifters but not for hydraulics. I'm sticking to factory specs since the car is factory original.
Chuck
Call Bob Karakashian AKA Mr Six Pack, 248-477-7776 for day, 248-489-4076 evenings or mr6pk@hotmail.com he will sell you a 3 bolt cam that will idle stock and kick a little bit harder.
The six pack cam is no different than a Road Runner cam profile wise. The unseen difference is the low taper lobe to deal with a bit more valve spring.
It is accepted by some that the original A12 cars came with cam profiles different from the typical HP cam, advertised early on with 276/292 duration. Interestingly enough very early literature for the 1967 440 4 speed GTXs advertised to have a cam carrying these specs as well, I'd assume the same for the Dodge R/T.
Got a Mr. Six Pack (Bob Karakashian)Cam in my otherwise stock 440 six pack car and it really rocks.....
Mr. Six Pack lives 4 miles from me, good guy for sure.
the cam and timing set are available from mancini; mopp4529270ae for the cam, mopp5249269 for the timing set. if you still have the original yellow stripe valve springs this is the cam profile that matched them. the mr. 6-pak cams are engles. i've tried a lot of "stock type" profiles in stock 440's and don't think there are any magic profiles. some i like better than others, but no single one arms and legs above the rest.
