gregs69
Hello, I have a 69 coronet with a 440 - 4 spd. I had an issue with the clutch fork and pivot. Changed them out on the car without taking out trans. Now, I started the car to adjust the clutch and getting a loud noise that appears to be coming from front of engine. The T/O bearing is not touching the fingers of the pressure plate. But when I push the clutch and it barely touches the fingers on the pressure plate, the noise goes away. Its like putting a tiny bit of pressure on the crank makes the noise go away. I tried moving the crank in and out front at the balancer and seem to have no play. Any ideas would be appreciated. I'm going to see if I can see anything touching around the balancer area.
Thanks in advance
Greg
Thanks in advance
Greg
