440 head question
boardog
6:38 AM
georgia
i have a very small water leak out of one of the front header bolts. Do all the exhaust bolt holes go into the water jacket? i am new to the mopar stuff and did not put sealant on the threads.
Use this on the threads. Works great on big block exhaust studs! $13.50 on Amazon. I had a leaker on my 383, sealed it with this back in 2012. Never leaked a drop since.
This is the product to use, and there's other places on the motor to use it as well.
R413 is correct. Some of the older heads had some blind holes, and some wet. The later heads that you are likely to have all have the holes wet, and need sealer.
I used the same permatex as above.
