SOLD 440 Heads - Performance Rebuild
GTX5877
10:35 AM
Albert Lea, MN
Feedback: +6 / =0 / -0
Freshly Rebuilt 440 Big Block Mopar cylinder heads. 1972 castings #3462'346', with factory induction hardened exhaust seats. Very similar to 906, 452, and 213 casting heads. Previously milled a bunch for compression. Now at 78 - 79cc, about 10+ ccs off. May require shorter pushrods!
2.08 & 1.74 Valves.
NEW Bronze guides, honed for proper clearance.
Multi-angle radius valve job.
NEW Comp Cams 911-16 Valve Springs for hydraulic or solid cams up to about .580" lift. Seat pressure is 125#@1.88" and open 320#@1.38" or 360#@1.28"
Springs shimmed to proper Installed Height.
NEW Viton race type positive valve seals. (pressed on guide)
There is over $850 worth of parts and machining costs not counting the value of the heads.
SELL FOR $550
Minnesota
If you click on thread tools, you can mark the ad 'sold' that way it'll show up in the index and save the members from clicking and reading the ad only to see they have been sold already....
