- 7:15 PM
- Dec 21, 2021
- Miserable Smells TX
Hello everybody, I know diagnosing over the internet is challenging, I’ll try to give as much information to describe what I’m dealing with.
I have a 1968 GTX with a 1969 C body 350 horse 440. I put 440 source aluminum heads on the car recently in attempt to help with the detonation issue I was having. It has an offenhauser 360 intake with a 4966s Carter avs currently. I have a Mallory unilite distributor with vacuum advance, and Mallory coil. My timing is at 12* initial, with the factory damper idk what the total timing is, but I can see it advances with rpm. I have a walbro 190 liter per hour pump, and a pressure regulator, the pressure gauge reads a constant steady 6lbs.
I installed an AEM AFR gauge, and with the 4966s it initially was pegged 18:1 leaned, and with rpm it would get a little richer but not much. So using an edelbrock 1407 tuning kit and chart I finally got 14:1, but only to 1,000 rpm, then it would drop to 16-17:1 until 2500rpm then it would peg the gauge at 10:1 rich and it would break up at 3,000rpm. Every change I made to that carb would do the same, it always dipped a point or 2 lean for a couple hundred rpm and then shoot way too rich without much in between.
So I decided to try a couple of different carburetors I had laying around. An edelbrock 1406 was 17:1 at idle, but with rpm would richen up to 11:1, and didn’t break up, I don’t have a tuning kit for it, so this was just to test a different carb. I also had a Carter 4327s afb, and it idled at 14:1, and richened up to 13:1 until 2,500rpm, where it would peg the gauge at 10:1 rich, and start breaking up at 3,000rpm.
I didn’t have the AFR gauge installed before the head swap so I don’t have a baseline to see if the heads are the issue or if it was acting similar before. I’m trying figure out what the issue might be and how I can correct it, as nothing I’ve tried has worked. Posting this in general as I’m not sure if I have a carburetor issue, ignition issue or a bit of both.
Any advice would be appreciated. Thanks!
