good suggestions "mostly"
I'd get/use heat shields, I have DEI on mine...
I have RPM angle plug heads too...
I've had good luck with the Summit Racing brand 8.5mm 50-ohm
I combined 2 sets, of straights/180* & 90*, IIRC $79 each
(used my Summit Bucks, no big deal, didn't cost me anything, to get a good set out of 2)
(you really can't get a good set of all the types needed, 45* 180* 90*
or multiple angles, run them away from every tube etc., it takes a combination
of styles/angle on a BBM)
you can also use the BB Chevy under the valve cover
depending on how you route them, if the BB MoPars aren't listed
depending on what type of cap you choose,
female or HEI style at the cap,
I'm pretty ****-retentive about my plug wires
& the routing & the resistance...
I find something that works & stick with it
I have E3s 40-ohm 8.5mm for my 99 Dakota,
I made out of all straight boots, from another build I had
I really like the quality of both, mentioned brands,
they look a lot alike & similar quality
I had Taylors 7mm for about 15 years on it (like 1200-1500 ohm per/foot)
the resistance was really bad, had troubles with plug 7 & 8 fouling
always a bit of a miss (after quite a bit of time, albeit)
the longest of the wires with the most resistance, 7 & 8
(like 4000-4200 ohms, don't tell me resistance doesn't matter)
after the change to the 8.5 Summit Racing brand/cheapos, knock off
(about 130-150 ohm on the longest wires max resistance),
all plugs read really well now, on all cylinders, no more lil' miss
good luck
