Thedeputy
I've been finetuning the 440 in my 66 Coronet 2dr sedan for some time and yesterday I took the car to a chassis dyno to do some final tuning and see how it would perform.
In the past months I checked out what kind of cam is installed, which should probably be a mp purple cam with 0.484" lift and a advertised duration of 239 @.50" lift.
It has a holley 4150 750 vacuum secondary single pumper carb with what appears to be a proform main body. The carb is mounted on top of a edelbrock performer rpm intake and breathes through an open K&N air cleaner.
I also measured cranking pressure which was around 165 psi on all cylinders.
Heads are 452's and exhaust gasses leave through some brand of long tube headers and a 2,5" H-pipe full exhaust system.
The final pull on the chassis dyno delivered a result of 341 hp @5300 rpm and 588 Nm (434 ft-lbs) @2900-3400 rpm.
The number is engine power, calculated by the dyno.
The car pulls hard on the road and is a blast to drive. It's not a race car. Street use only.
My question is: Are these respectable numbers for an engine like this?
Thanks,
Antoon
Thanks,
Antoon
