has2bmopar
Chronic mysterious over heating issues... BEWARE of cheap aluminum water pump housing
I am very surprised that no one has noticed the hideous poor casting of the inside of the cheap aftermarket aluminum water pump housings. I ordered one from 440 Source and noticed right away, the very restricted passenger side port, it is even worse inside around the corner/ inaccessible to 440 Sources suggestion to just port it to the correct size. I already had a new Mopar Performance housing in wait for my Hemi, and compared it to the cheap copy... The real Mopar housing is really open inside and the smallest point is the port at the gasket surface, matching the gasket. 440 Sources response was that their water pumps are so awesome it will never make a difference... B.S. The pressure being equal no matter the amount of pressure will favor in volume the path of least resistance, so the vast majority of flow will be given to the drivers side (left bank). Even if the over all flow was enough that it didn't show it was over heating at the sending unit, the right bank will be much hotter the left. Has anyone been scoring right bank cylinders? I was very unimpressed with 440 Sources refusal to refund my money, so I could buy a Mopar Housing, instead I had to dream up a possible future for some over priced ARP headbolts, as it would be store credit only and I had to eat the shipping both ways, for a part that would likely fry any engine, or maybe just half of it. My personal experience was with 440 Source, but beware of any of the lesser housings and inspect the ports, as I noticed at a Mopar event in Minnesota that the PRW is the SAME thing, and have seen others that are shrink rapped to a piece of cardboard so you can't see the ports or feel the heavily restricted internals. I did take pictures of both housings with the gasket laying on them. If people quit buying the afflicted ones, maybe they will correct the problem. Until then... In my opinion, pay more now to the company that designed the part, or you may pay dearly later for buying the cheap copied counterfeit.
